Ana içeriğe geç
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
Neye ihtiyacın var
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: adım 1, 3 resimden 1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: adım 1, 3 resimden 2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: adım 1, 3 resimden 3.
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: adım 2, 3 resimden 1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: adım 2, 3 resimden 2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: adım 2, 3 resimden 3.
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: adım 3, 2 resimden 1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: adım 3, 2 resimden 2.
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: adım 4, 2 resimden 1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: adım 4, 2 resimden 2.
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: adım 5, 2 resimden 1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: adım 5, 2 resimden 2.
    • Clean or lubricate the device if necessary.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
David Taylor
169 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-34, Donnelly Fall 2014 USF Tampa, Team 1-34, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G34
1 Üye
2 adet Kılavuz yazıldı
1Rehber Yorum
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 7,142
