Ana içeriğe geç
Andobil Easy Clip Car Mount Replacement
Neye ihtiyacın var
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: adım 1, 1 resimden 1.
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: adım 2, 1 resimden 1.
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: adım 3, 2 resimden 1. Andobil Easy Clip Car Mount Replacement: adım 3, 2 resimden 2.
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: adım 4, 1 resimden 1.
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: adım 5, 2 resimden 1. Andobil Easy Clip Car Mount Replacement: adım 5, 2 resimden 2.
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: adım 6, 1 resimden 1.
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: adım 7, 1 resimden 1.
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: adım 8, 1 resimden 1.
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: adım 9, 1 resimden 1.
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: adım 10, 1 resimden 1.
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Tavares
205 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 80
Her zaman: 2,194
