Ana içeriğe geç
Nobis NB09 Battery Replacement
Neye ihtiyacın var
  1. Nobis NB09 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: adım 2, 3 resimden 1. Nobis NB09 Battery Replacement: adım 2, 3 resimden 2. Nobis NB09 Battery Replacement: adım 2, 3 resimden 3.
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: adım 3, 2 resimden 1. Nobis NB09 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: adım 4, 1 resimden 1.
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: adım 5, 2 resimden 1. Nobis NB09 Battery Replacement: adım 5, 2 resimden 2.
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jackson McAdams
390 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G1
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
where can i buy a battery from
Frederick Shipman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,945
