Ana içeriğe geç
Android tablet Nobis NB09 Screen Replacement
Neye ihtiyacın var
  1. Android tablet Nobis NB09 Screen Replacement, Screen: adım 1, 3 resimden 1. Android tablet Nobis NB09 Screen Replacement, Screen: adım 1, 3 resimden 2. Android tablet Nobis NB09 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
    FixBot'a Sor
    Yorum Ekle
  2. Android tablet Nobis NB09 Screen Replacement: adım 2, 3 resimden 1. Android tablet Nobis NB09 Screen Replacement: adım 2, 3 resimden 2. Android tablet Nobis NB09 Screen Replacement: adım 2, 3 resimden 3.
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
    FixBot'a Sor
    Yorum Ekle
  3. Android tablet Nobis NB09 Screen Replacement: adım 3, 3 resimden 1. Android tablet Nobis NB09 Screen Replacement: adım 3, 3 resimden 2. Android tablet Nobis NB09 Screen Replacement: adım 3, 3 resimden 3.
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
    FixBot'a Sor
    Yorum Ekle
  4. Android tablet Nobis NB09 Screen Replacement: adım 4, 3 resimden 1. Android tablet Nobis NB09 Screen Replacement: adım 4, 3 resimden 2. Android tablet Nobis NB09 Screen Replacement: adım 4, 3 resimden 3.
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Enea Osmann
158 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 üyesi
UMASSD-CICHON-S15S7G1
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
The digitizer replacement instructions was great. Thanks
steven warren - Yanıt Paylaş
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,827
