Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Peel off the stickers. This will reveal the location of four screws.
Remove the four screws using a Phillips #0 screwdriver.
Use a spudger to pry apart the upper and lower housing of the mouse.
Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
Remove the scroll wheel from the mother board by pulling it to the left.
Pull the mother board gently away from the plastic housing.
Desolder the components and re-solder the replacements in order to repair the left and right buttons.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
where can these replacement button switches be purchased….thanks ric
