Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the mouse over so that the bottom is facing up.
Using a prying tool to peel off the black stickers from the bottom of the mouse.
Using the Phillips #0 screwdriver, remove the four screws from the bottom of the mouse.
Pry the panels apart gently using a plastic opening tool or spudger.
After separating the halves, remove the housing wires from the white crimp headers to separate the upper and lower housing units of the mouse.
Remove the two screws holding the board in place using a Phillips #0 screwdriver.
Remove the board from the housing unit and place it aside.
Left on the brown-colored bottom of the board, there are two black-and-white boxes. These are the side buttons.
Flip the board over to reveal the green-colored side.
Desolder the six silver pins to disconnect the side buttons.
Once desoldered, remove the old side buttons.
