Giriş
This is a step by step guide to replace the battery in the Anker SoundCore 2.
Before replacing anything, be sure to take a look at the troubleshooting page for this device.
Accessing the battery will involve removing the speakers and motherboard using a Philips #1 screwdriver.
Neye ihtiyacın var
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #1 screwdriver (Phillips #0 can strip the screw heads).
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Be careful not to damage the rubber gasket around the speaker mount plate.
Use your hand to remove the speakers. Some variants have a wire from the speaker to the board, some rest on contact pins.
8 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
Kapazität 2600 mAh Leistung 19.24 Wh Spannung 7.4 V Typ Li-ion
