Ana içeriğe geç
Anker SoundCore 2 Speaker Replacement
Neye ihtiyacın var
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: adım 1, 2 resimden 1. Anker SoundCore 2 Speaker Replacement, Front Panel: adım 1, 2 resimden 2.
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    FixBot'a Sor
    Yorum Ekle
  2. Anker SoundCore 2 Speaker Replacement, Speaker: adım 2, 3 resimden 1. Anker SoundCore 2 Speaker Replacement, Speaker: adım 2, 3 resimden 2. Anker SoundCore 2 Speaker Replacement, Speaker: adım 2, 3 resimden 3.
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
    FixBot'a Sor
    Yorum Ekle
  3. Anker SoundCore 2 Speaker Replacement: adım 3, 3 resimden 1. Anker SoundCore 2 Speaker Replacement: adım 3, 3 resimden 2. Anker SoundCore 2 Speaker Replacement: adım 3, 3 resimden 3.
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
13Kılavuz Yorumları
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Yanıt Paylaş
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Yanıt Paylaş
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez - Yanıt Paylaş
@philcuchetti I have a soundcore select 1 which is an older model and it seems to have the same speaker which I found here https://www.aliexpress.com/item/10050091...
JSound - Yanıt Paylaş
Do someone get a new speaker? I need to buy one!
everton.euclides - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 39
Son 30 gün: 133
Her zaman: 7,365
