Ana içeriğe geç
Anker Soundcore Flare Mini Audio Drivers Replacement
Neye ihtiyacın var
  1. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: adım 1, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: adım 1, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 2, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 2, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 2, 3 resimden 3.
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: adım 3, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: adım 3, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: adım 3, 3 resimden 3.
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
    FixBot'a Sor
    Yorum Ekle
  4. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 4, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 4, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 4, 3 resimden 3.
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
    FixBot'a Sor
    Yorum Ekle
  5. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: adım 5, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: adım 5, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: adım 5, 3 resimden 3.
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
    FixBot'a Sor
    Yorum Ekle
  6. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 6, 2 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 6, 2 resimden 2.
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 7, 1 resimden 1.
    • Pull the charging port away from the side of the speaker.
    FixBot'a Sor
    Yorum Ekle
  8. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 8, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 8, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 8, 3 resimden 3.
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
    FixBot'a Sor
    Yorum Ekle
  9. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: adım 9, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: adım 9, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: adım 9, 3 resimden 3.
    • There are two drivers—one on each side of the speaker.
    • Use a Phillips #1 screwdriver to remove the four 11 mm screws from one driver.
    • Use your hand to pull the driver out of the device.
    • Repeat this step with the other driver.
    FixBot'a Sor
    Yorum Ekle
  10. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 10, 3 resimden 1. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 10, 3 resimden 2. Anker Soundcore Flare Mini Audio Drivers Replacement: adım 10, 3 resimden 3.
    • Use precision tweezers to detach the two wire connectors from the driver.
    • Both drivers are connected to the same wire so removing one side will separate the other driver from the device as well.
    • Remove both drivers from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
what size are the speakers?
Chris - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 48
Her zaman: 1,505
