Ana içeriğe geç
Anker Soundcore Select Pro A 3126 Button Panel Replacement
Neye ihtiyacın var
  1. Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: adım 1, 2 resimden 1. Anker Soundcore Select Pro A 3126 Button Panel Replacement, Button Panel: adım 1, 2 resimden 2.
    • Use a spudger to remove each side speaker cover by inserting it in the crevice and using moderate force to pry them off.
    FixBot'a Sor
    Yorum Ekle
  2. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 2, 2 resimden 1. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 2, 2 resimden 2.
    • Insert a spudger into the space between the grille and speaker frame to pry the mesh grille covering the front speakers.
    FixBot'a Sor
    Yorum Ekle
  3. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the eight 12.7 mm screws securing the front cover.
    FixBot'a Sor
    Yorum Ekle
  4. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the eight 8.75 mm screws around the corners of each speaker.
    FixBot'a Sor
    Yorum Ekle
  5. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 5, 1 resimden 1.
    • Flip the speaker so you have access to the bottom of the device.
    • Use a spudger to remove both rubber pads that protect the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  6. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 6, 1 resimden 1.
    • Using a spudger remove the rubber pad on the top handle to expose 3 screws underneath.
    • Using a Phillips #1 screwdriver, remove the three 6.75 mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 7, 3 resimden 1. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 7, 3 resimden 2. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 7, 3 resimden 3.
    • Using a spudger, pry open the front half of the speaker.
    • The front and back halves of the speaker are connected by several cables. Open the speaker slowly and avoid pulling on the cables, as they can be damaged easily.
    FixBot'a Sor
    Yorum Ekle
  8. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the eight 6.5 mm screws securing the button board.
    FixBot'a Sor
    Yorum Ekle
  9. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 9, 2 resimden 1. Anker Soundcore Select Pro A 3126 Button Panel Replacement: adım 9, 2 resimden 2.
    • Use the tip of the spudger to push the black plastic locking tab away from the socket.
    • Pull the ribbon cable straight out of the socket.
    • Remove the old button board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Matthew Garza
387 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 52
Her zaman: 75
