Ana içeriğe geç
Anker Soundcore Space One Ear Pad Replacement
Neye ihtiyacın var
    1. Anker Soundcore Space One Ear Pad Replacement, Ear Pads: adım 1, 1 resimden 1.
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      FixBot'a Sor
      Yorum Ekle
    2. Anker Soundcore Space One Ear Pad Replacement: adım 2, 2 resimden 1. Anker Soundcore Space One Ear Pad Replacement: adım 2, 2 resimden 2.
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      FixBot'a Sor
      Yorum Ekle
    3. Anker Soundcore Space One Ear Pad Replacement: adım 3, 1 resimden 1.
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Malcolm Hewlett
433 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S2G3
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 69
Son 30 gün: 294
Her zaman: 1,898
