Ana içeriğe geç
Anne Pro 2 Case/Housing Replacement
Neye ihtiyacın var
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: adım 1, 3 resimden 1. Anne Pro 2 Case/Housing Replacement, Case/Housing: adım 1, 3 resimden 2. Anne Pro 2 Case/Housing Replacement, Case/Housing: adım 1, 3 resimden 3.
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: adım 2, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 2, 2 resimden 2.
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: adım 3, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 3, 2 resimden 2.
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: adım 4, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: adım 5, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 5, 2 resimden 2.
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: adım 6, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 6, 2 resimden 2.
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: adım 7, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 7, 2 resimden 2.
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: adım 8, 2 resimden 1. Anne Pro 2 Case/Housing Replacement: adım 8, 2 resimden 2.
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mohamed
205 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 86
Her zaman: 10,176
