Ana içeriğe geç
Anne Pro 2 Keyboard Keycaps Replacement
Neye ihtiyacın var
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: adım 1, 1 resimden 1.
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 1. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 2. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 3.
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: adım 3, 2 resimden 1. Anne Pro 2 Keyboard Keycaps Replacement: adım 3, 2 resimden 2.
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: adım 4, 1 resimden 1.
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: adım 5, 1 resimden 1.
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Omar Sukkar
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 1,925
