Ana içeriğe geç
Anne Pro 2 Keyboard Keycaps Replacement
Neye ihtiyacın var
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: adım 1, 1 resimden 1.
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
    FixBot'a Sor
    Yorum Ekle
  2. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 1. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 2. Anne Pro 2 Keyboard Keycaps Replacement: adım 2, 3 resimden 3.
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
    FixBot'a Sor
    Yorum Ekle
  3. Anne Pro 2 Keyboard Keycaps Replacement: adım 3, 2 resimden 1. Anne Pro 2 Keyboard Keycaps Replacement: adım 3, 2 resimden 2.
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
    FixBot'a Sor
    Yorum Ekle
  4. Anne Pro 2 Keyboard Keycaps Replacement: adım 4, 1 resimden 1.
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
    FixBot'a Sor
    Yorum Ekle
  5. Anne Pro 2 Keyboard Keycaps Replacement: adım 5, 1 resimden 1.
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Omar Sukkar
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 2,683
