Ana içeriğe geç
Answering Machine Speaker Replacement
Neye ihtiyacın var
  1. Answering Machine Speaker Replacement, Base: adım 1, 1 resimden 1.
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: adım 2, 2 resimden 1. Answering Machine Speaker Replacement: adım 2, 2 resimden 2.
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: adım 3, 2 resimden 1. Answering Machine Speaker Replacement, Answering Machine Speaker: adım 3, 2 resimden 2.
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: adım 4, 1 resimden 1.
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: adım 5, 1 resimden 1.
Sonuç
Troy Chester
66 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Fall 2016 IUPUI, Team 3-3, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G3
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 627
