Ana içeriğe geç
Aorus X7 v2 I/O Board Replacement
Neye ihtiyacın var
  1. Aorus X7 v2 I/O Board Replacement, I/O Board: adım 1, 3 resimden 1. Aorus X7 v2 I/O Board Replacement, I/O Board: adım 1, 3 resimden 2. Aorus X7 v2 I/O Board Replacement, I/O Board: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $5.49
    Satın Al
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Locate the speaker on the right-hand side of the device.
    • Remove the four red and black braided cables by gripping the black plastic piece on each cable and gently tugging to separate it from the white outlet.
  2. Aorus X7 v2 I/O Board Replacement: adım 2, 3 resimden 1. Aorus X7 v2 I/O Board Replacement: adım 2, 3 resimden 2. Aorus X7 v2 I/O Board Replacement: adım 2, 3 resimden 3.
    Phillips #0 Screwdriver
    $5.49
    Satın Al
    • Use the Phillips #0 Screwdriver to remove the two screws holding the speaker in place. Lift off the speaker panel.
    • Use the Phillips #0 Screwdriver to remove the three screws holding the board in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
  3. Aorus X7 v2 I/O Board Replacement: adım 3, 3 resimden 1. Aorus X7 v2 I/O Board Replacement: adım 3, 3 resimden 2. Aorus X7 v2 I/O Board Replacement: adım 3, 3 resimden 3.
    $5.49
    Satın Al
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the screw.
    • Place a finger under the board (see photo for location reference) and slowly lift up to remove the board.
Sonuç
Complete these steps in reverse order to install your new I/O Board.
Bir başkası bu kılavuzu tamamladı.
Alexis Hernandez Jimenez
572 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2022 Gateway, Team 1-4, Pee Fall 2022 üyesi
GCC-PEE-F22S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 347
