Giriş
Follow these steps to replace the Aorus X7 v2 I/O Board for better sound quality and performance. Replacing the board can improve hardware support, graphics performance, and increase computer speed. It's recommended to replace the board every 2-4 years, but it can last up to 8 years. All you need is a new board, standard tools, and this guide to get started.
Neye ihtiyacın var
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49
Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
Locate the speaker on the right-hand side of the device.
Remove the four red and black braided cables by gripping the black plastic piece on each cable and gently tugging to separate it from the white outlet.
Bu adımda kullanılan alet:Phillips #0 Screwdriver$5.49
Use the Phillips #0 Screwdriver to remove the two screws holding the speaker in place. Lift off the speaker panel.
Use the Phillips #0 Screwdriver to remove the three screws holding the board in place.
Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
Gently pull off the inner black ribbon to remove it from the board.
Use the Phillips #0 Screwdriver to remove the screw.
Place a finger under the board (see photo for location reference) and slowly lift up to remove the board.
Complete these steps in reverse order to install your new I/O Board.
Bir başkası bu kılavuzu tamamladı.
