Ana içeriğe geç
Aorus x7 v2 Fan Assembly Replacement
Neye ihtiyacın var
  1. Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: adım 1, 3 resimden 1. Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: adım 1, 3 resimden 2. Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: adım 1, 3 resimden 3.
    • Flip the laptop over.
    • Unscrew the 12 screws holding on the bottom cover.
    • Take off the bottom cover.
    • Remove the 12 screws from the heat sink.
  2. Aorus x7 v2 Fan Assembly Replacement: adım 2, 3 resimden 1. Aorus x7 v2 Fan Assembly Replacement: adım 2, 3 resimden 2. Aorus x7 v2 Fan Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the heat sinks one by one.
  3. Aorus x7 v2 Fan Assembly Replacement: adım 3, 3 resimden 1. Aorus x7 v2 Fan Assembly Replacement: adım 3, 3 resimden 2. Aorus x7 v2 Fan Assembly Replacement: adım 3, 3 resimden 3.
    • Unscrew the six screws from the right fan.
    • Unscrew the six screws from the left fan.
    • Locate the connection plug for the fan to the motherboard and disconnect the left fan connector.
  4. Aorus x7 v2 Fan Assembly Replacement: adım 4, 3 resimden 1. Aorus x7 v2 Fan Assembly Replacement: adım 4, 3 resimden 2. Aorus x7 v2 Fan Assembly Replacement: adım 4, 3 resimden 3.
    • Disconnect the right fan connector.
    • Carefully lift up the left and right fans.
    • Set the fans to the side before installing new fans.
Sonuç
To reassemble your device, follow these instructions in reverse order using new left and right fans.
Alexis Hernandez Jimenez
572 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Fall 2022 Gateway, Team 1-4, Pee Fall 2022 üyesi
GCC-PEE-F22S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 368
