Ana içeriğe geç
Aoson R103 Device Page Glass Screen Replacement
Neye ihtiyacın var
  1. Aoson R103 Device Page Glass Screen Replacement, Device: adım 1, 3 resimden 1. Aoson R103 Device Page Glass Screen Replacement, Device: adım 1, 3 resimden 2. Aoson R103 Device Page Glass Screen Replacement, Device: adım 1, 3 resimden 3.
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may require some force, as they are connected by push tabs.
    • Be careful not to drop the device when separating, as this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Device Page Glass Screen Replacement: adım 2, 2 resimden 1. Aoson R103 Device Page Glass Screen Replacement: adım 2, 2 resimden 2.
    • Use your fingers to unclip the ribbon connector and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on.
  3. Aoson R103 Device Page Glass Screen Replacement, Glass Screen: adım 3, 2 resimden 1. Aoson R103 Device Page Glass Screen Replacement, Glass Screen: adım 3, 2 resimden 2.
    • Locate the four (0.4 mm) screws positioned near the cameras at the top of the device, and use a screwdriver to unscrew them. (Circles).
  4. Aoson R103 Device Page Glass Screen Replacement: adım 4, 2 resimden 1. Aoson R103 Device Page Glass Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • To disconnect the ribbon connectors, first, you need to flip up the tabs located above the ribbon gently. This will release the ribbon from the connector. Then, you can use tweezers to gently pull the ribbon out of the connector. Remember to be careful and avoid pulling too hard to prevent damage to the ribbon or connector.
  5. Aoson R103 Device Page Glass Screen Replacement: adım 5, 3 resimden 1. Aoson R103 Device Page Glass Screen Replacement: adım 5, 3 resimden 2. Aoson R103 Device Page Glass Screen Replacement: adım 5, 3 resimden 3.
    • Remove the glass screen by unfastening all of the clasps located around the outer edge of the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 472
