Ana içeriğe geç
Apex Digital DTV Converter Box Power supply Board replacement
Neye ihtiyacın var
  1. Apex Digital DTV Converter Box Power supply Board replacement, Power Board: adım 1, 1 resimden 1.
    • Unplug your device from the wall outlet.
  2. Apex Digital DTV Converter Box Power supply Board replacement: adım 2, 1 resimden 1.
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
  3. Apex Digital DTV Converter Box Power supply Board replacement: adım 3, 1 resimden 1.
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  4. Apex Digital DTV Converter Box Power supply Board replacement: adım 4, 1 resimden 1.
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
  5. Apex Digital DTV Converter Box Power supply Board replacement: adım 5, 1 resimden 1.
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
  6. Apex Digital DTV Converter Box Power supply Board replacement: adım 6, 1 resimden 1.
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
  7. Apex Digital DTV Converter Box Power supply Board replacement: adım 7, 1 resimden 1.
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
  8. Apex Digital DTV Converter Box Power supply Board replacement: adım 8, 1 resimden 1.
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
  9. Apex Digital DTV Converter Box Power supply Board replacement: adım 9, 1 resimden 1.
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
  10. Apex Digital DTV Converter Box Power supply Board replacement: adım 10, 1 resimden 1.
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Michel
288 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 9,036
