Ana içeriğe geç
Apex TM772 Casing Removal
Neye ihtiyacın var
  1. Apex TM772 Casing Removal, Casing: adım 1, 1 resimden 1.
    • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
  2. Apex TM772 Casing Removal: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Moving along the seam continue to pry the case apart.
    • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
  3. Apex TM772 Casing Removal: adım 3, 1 resimden 1.
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 158
