Ana içeriğe geç
Apex Tablet 7 Back Panel Replacement
Neye ihtiyacın var
  1. Apex Tablet 7 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
    FixBot'a Sor
    Yorum Ekle
  2. Apex Tablet 7 Back Panel Replacement: adım 2, 2 resimden 1. Apex Tablet 7 Back Panel Replacement: adım 2, 2 resimden 2.
    • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
    • This connection is shown in red on the pictures.
    FixBot'a Sor
    Yorum Ekle
  3. Apex Tablet 7 Back Panel Replacement: adım 3, 2 resimden 1. Apex Tablet 7 Back Panel Replacement: adım 3, 2 resimden 2.
    • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
    • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
    FixBot'a Sor
    Yorum Ekle
  4. Apex Tablet 7 Back Panel Replacement: adım 4, 1 resimden 1.
    • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
    FixBot'a Sor
    Yorum Ekle
  5. Apex Tablet 7 Back Panel Replacement: adım 5, 1 resimden 1.
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Steven Gutzwiller
480 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 2-2, Grigsby Spring 2015 Baylor, Team 2-2, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 1,047
