Giriş
This guide will show you how to remove the back panel, locate the volume control button, and remove and replace the volume button on your Apex tablet.
Neye ihtiyacın var
Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
The volume button is located as shown in the picture.
Once the screws are out, use a plastic opening tool to gently apply pressure on the edge of the circuit board against the edge of the tablet. This will pop each of the component heads out of their sockets on the edge of the tablet, leaving the circuit board loose inside.
Using a plastic opening tool, gently lift the loose circuit board up and away from the back of the tablet.
If the button did not fall out on its own, push the circuit board up with one tool while gently pushing inwards on the volume button with another tool to dislodge it.
The button will fall out under the circuit board.
Hold the circuit board up with the prying tool and extract the loose button with tweezers.
My unit does not have screws. How do I open it? Do I pry it opened between the front and back panels?
Fred Amato - Yanıt
