Ana içeriğe geç
Apple AirPort Extreme Model A1034 Internet Card Replacement
Neye ihtiyacın var
    1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: adım 1, 1 resimden 1.
      • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
      FixBot'a Sor
      Yorum Ekle
    2. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 2, 1 resimden 1.
      • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 3, 2 resimden 1. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 3, 2 resimden 2.
      • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
      FixBot'a Sor
      Yorum Ekle
    4. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 4, 1 resimden 1.
      • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
      FixBot'a Sor
      Yorum Ekle
    1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: adım 5, 1 resimden 1.
      • Remove four 1mm phillips screws from the bottom.
      FixBot'a Sor
      Yorum Ekle
    2. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 6, 1 resimden 1.
      • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
      • To remove the AirPort card, gently pull the plastic tab horizontally.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Michael Garcia
417 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G15
3 Üyeler
21 adet Kılavuz yazıldı
1Rehber Yorum
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 5,710
