Ana içeriğe geç
Apple AirPort Extreme Model A1034 Internet Card Replacement
Neye ihtiyacın var
  1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 2, 1 resimden 1.
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 3, 2 resimden 1. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 3, 2 resimden 2.
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 4, 1 resimden 1.
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: adım 5, 1 resimden 1.
    • Remove four 1mm phillips screws from the bottom.
  6. Apple AirPort Extreme Model A1034 Internet Card Replacement: adım 6, 1 resimden 1.
    • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Garcia
411 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G15
3 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 5,150
