Ana içeriğe geç
Apple AirPort Extreme Model A1034 Motherboard Replacement
Neye ihtiyacın var
  1. Apple AirPort Extreme Model A1034 Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 3, 2 resimden 1. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 7, 1 resimden 1.
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 8, 2 resimden 1. Apple AirPort Extreme Model A1034 Motherboard Replacement: adım 8, 2 resimden 2.
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Michael Garcia
411 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G15
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 5,971
