Ana içeriğe geç
Apple AirPort Extreme Model A1143 Case Replacement
Neye ihtiyacın var
  1. Apple AirPort Extreme Model A1143 Case Replacement, Back Pad: adım 1, 1 resimden 1.
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Case Replacement, Back Cover: adım 2, 1 resimden 1.
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Case Replacement: adım 3, 1 resimden 1.
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Case Replacement, Remove from Case: adım 4, 1 resimden 1.
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Zak
616 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G4
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 3,243
