Ana içeriğe geç
Apple AirPort Extreme Model A1143 Logic Board Replacement
Görüntüleme: 3,2 B
İstatistikleri görüntüle:
Son 24 Saat:
2
Son 7 Gün:
15
Son 30 Gün:
88
Her zaman:
3.222
Yorumlar: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Tamamlandı: 3
3 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: 1 - 2 dakika
Zorluk: Kolay
This is another guide that will be used for several repairs. The logic board is the most frequently replaced part for this device as individual parts are hard to come by.
Neye ihtiyacın var
Aletler
    1. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Pad: adım 1, 1 resimden 1.
      • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
      • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
      FixBot'a Sor
      Yorum Ekle
    2. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Cover: adım 2, 1 resimden 1.
      • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
      FixBot'a Sor
      Yorum Ekle
    3. Apple AirPort Extreme Model A1143 Logic Board Replacement: adım 3, 1 resimden 1.
      • Lift up the back case from the perforated edge to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove from Case: adım 4, 1 resimden 1.
      • Remove logic board and metal casing from outer case by prying from one side using a spudger.
      FixBot'a Sor
      Yorum Ekle
    1. Apple AirPort Extreme Model A1143 Logic Board Replacement, Detach Logic Board From Case: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. Apple AirPort Extreme Model A1143 Logic Board Replacement, Pull Back Tabs: adım 6, 1 resimden 1.
      • Carefully push back the three metal tabs with your fingers on the sides of metal case.
      FixBot'a Sor
      Yorum Ekle
    3. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove Metal case: adım 7, 1 resimden 1.
      • Carefully pull the metal case away from the logic board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zak
622 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S12G4
5 Üyeler
60 adet Kılavuz yazıldı
1Rehber Yorum
my apple a1143 wont turn on at all no light.
what can it be done?
Gabriel barradenguy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 88
Her zaman: 3,222
