Giriş
The three WiFi antenna are very fragile and sensitive. Be very careful when removing and replacing them, as touching the replacement antenna can cause them to not function at peak efficiency. The old antenna do not require the same care, though you should avoid bending or forcing to remove the antenna because they could snap and ruin the device. Also be careful with the metal attached to the antenna can bend and cause the metal casing to not fit back together with the other pieces.
Neye ihtiyacın var
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
Bu adımda kullanılan alet:Tweezers$4.99
Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
Carefully push back the three metal tabs with your fingers on the sides of metal case.
Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
Pull away antennas from metal case.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Thanks for the guide.
Pulled mine apart to examine the battery inside. It measured above 3.1 volts - even though it has been in use since June 2008 (about 9 years).
Holes will be punched for access to the 5 screws so the rubber pad does not have to be removed if it needs to be opened in the future.
I may see about buying a new Ac adapter to power this Airport Extreme since that is probably why the status light on the front did not illuminate.
Completed this. Didnt use apple replacement antennas. Added 3 U.FL Mini PCI to RP-SMA Pigtails, drilled 3 holes and mounted 3 +9db antennas. My wifi finally reaches my garage
