Giriş
If the base station does not turn on, the battery may need to be replaced.
Neye ihtiyacın var
First start by peeling off the outer rubbery covering on the bottom of the device.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
7 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Hi! How to know i need to change battery? What the symptoms of dead battery? My Airport Extreme worked well 6 years, and now its have the problems, missing pings, can it be symptom of dead battery?
