Ana içeriğe geç
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Neye ihtiyacın var
  1. Apple AirPort Extreme Model A1354 WiFi Card Replacement, Outer Case: adım 1, 1 resimden 1.
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 2, 1 resimden 1.
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 3, 1 resimden 1.
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 4, 3 resimden 1. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 4, 3 resimden 2. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 4, 3 resimden 3.
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 5, 1 resimden 1.
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 WiFi Card Replacement, WiFi Card: adım 6, 1 resimden 1.
    • Take the device out of the casing and orient it so that you can see the WiFi card.
  7. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 7, 1 resimden 1.
    • Wires come from the three antennas and connect on the outer edge of the WiFi card.
    • Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
    • Do this for the remaining two wires.
  8. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 8, 1 resimden 1.
    • There are two clips attached to the upper and lower ends of the WiFi card
    • CAUTION: For the following step, do not pull the clip after you have detached it. The clip is fragile and too much force may cause the clip to break.
    • Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
    • Do the same for the other clip.
  9. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 9, 2 resimden 1. Apple AirPort Extreme Model A1354 WiFi Card Replacement: adım 9, 2 resimden 2.
    • Grasp the upper and lower ends of the WiFi card.
    • Carefully pull the WiFi card to the right.
    • CAUTION: Do not pull UP (towards yourself) on the WiFi card when removing. The card is on a track that only allows it to move left and right. Forcing the card to move in other directions may result in breaking the track.
    • Completely remove the WiFi card.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Daniel Wagstaffe
115 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 üyesi
CPSU-FORTE-S12S5G2
5 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
this is a1143 model not a1354
allls - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 28
Her zaman: 9,170
