Ana içeriğe geç
Apple Airport Extreme Model A1408 Outer Case Replacement
Neye ihtiyacın var
    1. Apple Airport Extreme Model A1408 Outer Case Replacement, Back Pad: adım 1, 1 resimden 1.
      • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
      • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
      FixBot'a Sor
      Yorum Ekle
    2. Apple Airport Extreme Model A1408 Outer Case Replacement: adım 2, 1 resimden 1.
      • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
      • Use heat in areas where the glue is not loose enough.
      • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
      FixBot'a Sor
      Yorum Ekle
    1. Apple Airport Extreme Model A1408 Outer Case Replacement, Outer Case: adım 3, 2 resimden 1. Apple Airport Extreme Model A1408 Outer Case Replacement, Outer Case: adım 3, 2 resimden 2.
      • After removing the back pad, unscrew the five 5 mm Phillips #00 screws in the large, deep holes in the plastic casing. The plastic casing should come off easily after removing all the screws.
      • When installing the plastic back cover, ensure the lip is aligned with the ports on the back of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Apple Airport Extreme Model A1408 Outer Case Replacement: adım 4, 2 resimden 1. Apple Airport Extreme Model A1408 Outer Case Replacement: adım 4, 2 resimden 2.
      • Insert a narrow plastic opening tool into one of the notches. Apply moderate force to pull the metal casing from the plastic outer casing. You can use the rim of the outer case as leverage. You should hear a click when the metal casing detaches.
      • After you hear the click, remove the inner metal case from the outer case using your hands. It should not take very much force.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jada Evers
296 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G37
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 43
Her zaman: 2,995
