Giriş
This guide will show you how to gain access to the LCD Control Board on an Apple Cinema Display.
Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Carefully remove the two tape plugs on either side of the control board using a spudger.
Bir başkası bu kılavuzu tamamladı.
