Ana içeriğe geç
Apple Extended Keyboard A1243 Key Replacement
Neye ihtiyacın var
  1. Apple Extended Keyboard A1243 Key Replacement, Key: adım 1, 1 resimden 1.
    • Place the keyboard on a flat surface.
  2. Apple Extended Keyboard A1243 Key Replacement: adım 2, 1 resimden 1.
    • Inspect the key that is stuck or the key mechanism where the missing key was.
  3. Apple Extended Keyboard A1243 Key Replacement: adım 3, 2 resimden 1. Apple Extended Keyboard A1243 Key Replacement: adım 3, 2 resimden 2.
    • If the key is stuck, gently insert a spudger under the edge of the keycap.
    • Start from one corner and carefully pry the keycap from the keyboard, working your way around it until it pops out.
    • Inspect the key mechanism (scissor switch under the keycap) for any damage or debris.
    • If the keycap is dirty, clean it by soaking it in warm soapy water.
    • Ensure the key mechanism and cap are dry before reassembling.
  4. Apple Extended Keyboard A1243 Key Replacement: adım 4, 2 resimden 1. Apple Extended Keyboard A1243 Key Replacement: adım 4, 2 resimden 2.
    • If the mechanism is damaged, you will need to replace it.
    • Install the new or previously removed key by aligning the keycap with the key mechanism. Align the top of the scissor-switch to the metal notches on the keyboard and then align the bottom of the switch, ensuring you hook the scissor-switch onto the metal tab on the keyboard.
    • Press down firmly on the keycap until it snaps into place.
  5. Apple Extended Keyboard A1243 Key Replacement: adım 5, 1 resimden 1.
    • Test the key by plugging in or turning the keyboard on to see if it works correctly.
Bitiş Çizgisi
Laura Caucci
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 64
Son 30 gün: 259
Her zaman: 1,534
