Ana içeriğe geç
Apple IIc Floppy Drive Replacement
Neye ihtiyacın var
  1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 1. Apple IIc Floppy Drive Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 2.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Apple IIc Floppy Drive Replacement: adım 2, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 2, 2 resimden 2.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    FixBot'a Sor
    Yorum Ekle
  3. Apple IIc Floppy Drive Replacement: adım 3, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 3, 2 resimden 2.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    FixBot'a Sor
    Yorum Ekle
  4. Apple IIc Floppy Drive Replacement: adım 4, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 4, 2 resimden 2.
    • Lift the handle straight up to remove.
    FixBot'a Sor
    Yorum Ekle
  5. Apple IIc Floppy Drive Replacement, Keyboard: adım 5, 2 resimden 1. Apple IIc Floppy Drive Replacement, Keyboard: adım 5, 2 resimden 2.
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    FixBot'a Sor
    Yorum Ekle
  6. Apple IIc Floppy Drive Replacement, Floppy Drive: adım 6, 2 resimden 1. Apple IIc Floppy Drive Replacement, Floppy Drive: adım 6, 2 resimden 2.
    • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
    FixBot'a Sor
    Yorum Ekle
  7. Apple IIc Floppy Drive Replacement: adım 7, 3 resimden 1. Apple IIc Floppy Drive Replacement: adım 7, 3 resimden 2. Apple IIc Floppy Drive Replacement: adım 7, 3 resimden 3.
    • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
    FixBot'a Sor
    Yorum Ekle
  8. Apple IIc Floppy Drive Replacement: adım 8, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 8, 2 resimden 2.
    • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
    FixBot'a Sor
    Yorum Ekle
  9. Apple IIc Floppy Drive Replacement: adım 9, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 9, 2 resimden 2.
    • Carefully lift the floppy drive cage straight up to remove it.
    FixBot'a Sor
    Yorum Ekle
  10. Apple IIc Floppy Drive Replacement: adım 10, 2 resimden 1. Apple IIc Floppy Drive Replacement: adım 10, 2 resimden 2.
    • Lift the floppy drive straight up to remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Alexandria Weinberg
601 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 6,290
