Ana içeriğe geç
Apple IIc Keyboard Replacement
Neye ihtiyacın var
  1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 2.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    FixBot'a Sor
  2. Apple IIc Keyboard Replacement: adım 2, 2 resimden 1. Apple IIc Keyboard Replacement: adım 2, 2 resimden 2.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    FixBot'a Sor
  3. Apple IIc Keyboard Replacement: adım 3, 2 resimden 1. Apple IIc Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    FixBot'a Sor
  4. Apple IIc Keyboard Replacement: adım 4, 2 resimden 1. Apple IIc Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift the handle straight up to remove.
    FixBot'a Sor
  5. Apple IIc Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. Apple IIc Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    FixBot'a Sor
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexandria Weinberg
601 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 13
Son 30 gün: 70
Her zaman: 3,973
