Ana içeriğe geç
Apple IIc Power Converter Replacement
Neye ihtiyacın var
  1. Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 1. Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: adım 1, 2 resimden 2.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Apple IIc Power Converter Replacement: adım 2, 2 resimden 1. Apple IIc Power Converter Replacement: adım 2, 2 resimden 2.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    FixBot'a Sor
    Yorum Ekle
  3. Apple IIc Power Converter Replacement: adım 3, 2 resimden 1. Apple IIc Power Converter Replacement: adım 3, 2 resimden 2.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    FixBot'a Sor
    Yorum Ekle
  4. Apple IIc Power Converter Replacement: adım 4, 2 resimden 1. Apple IIc Power Converter Replacement: adım 4, 2 resimden 2.
    • Lift the handle straight up to remove.
    FixBot'a Sor
    Yorum Ekle
  5. Apple IIc Power Converter Replacement, Power Converter: adım 5, 1 resimden 1.
    • Remove the two 7.7mm length Phillips screws that secure the power converter.
    FixBot'a Sor
    Yorum Ekle
  6. Apple IIc Power Converter Replacement: adım 6, 2 resimden 1. Apple IIc Power Converter Replacement: adım 6, 2 resimden 2.
    • Grab the back of the power supply and pull out while lifting up so that it will clear the other components.
    • The power supply can be difficult to remove so be careful not to bend or damage any nearby components while you pull out the power supply.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Josiah
658 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G23
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 46
Her zaman: 4,978
