Ana içeriğe geç
Apple Lisa Disassembly
Neye ihtiyacın var
  1. Apple Lisa Disassembly, Prepare Workspace: adım 1, 1 resimden 1.
    • Place the Lisa on a safe/sturdy surface.
  2. Apple Lisa Disassembly, Removing Front Panel: adım 2, 2 resimden 1. Apple Lisa Disassembly, Removing Front Panel: adım 2, 2 resimden 2.
    • Press the two tabs underneath to release the panel.
  3. Apple Lisa Disassembly, Remove Drive Cage: adım 3, 1 resimden 1.
    • Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
  4. Apple Lisa Disassembly, Remove Back Panel: adım 4, 2 resimden 1. Apple Lisa Disassembly, Remove Back Panel: adım 4, 2 resimden 2.
    • Twist thumbscrews on the back to release the panel. Pull panel up to remove.
  5. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 1. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 2. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 3.
    • Release the thumbscrew on the power supply. Pull out the power supply.
  6. Apple Lisa Disassembly, Remove Cardcage: adım 6, 2 resimden 1. Apple Lisa Disassembly, Remove Cardcage: adım 6, 2 resimden 2.
    • Grab the card cage at the location shown and pull out.
  7. Apple Lisa Disassembly, Remove Top: adım 7, 2 resimden 1. Apple Lisa Disassembly, Remove Top: adım 7, 2 resimden 2.
    • Unscrew two philips screws on the ceiling of where the card cage was.
  8. Apple Lisa Disassembly, Remove Power Switch: adım 8, 2 resimden 1. Apple Lisa Disassembly, Remove Power Switch: adım 8, 2 resimden 2.
    • Release two screws and release the ribbon cable.
  9. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 1. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 2. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 3.
    • Remove all screws shown.
  10. Apple Lisa Disassembly, Remove Left Panel: adım 10, 2 resimden 1. Apple Lisa Disassembly, Remove Left Panel: adım 10, 2 resimden 2.
  11. Apple Lisa Disassembly, Remove Feet Panel: adım 11, 1 resimden 1.
  12. Apple Lisa Disassembly, Remove Bottom Pannel: adım 12, 1 resimden 1.
  13. Apple Lisa Disassembly, CRT: adım 13, 1 resimden 1.
    • I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
  14. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 1. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 2. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 3.
    • Pull up on the tabs to remove cards.
  15. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 1. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 2. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 3.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
LisaGuide
1.833 İtibar
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 2,141
