Ana içeriğe geç
Apple Lisa Disassembly
Neye ihtiyacın var
  1. Apple Lisa Disassembly, Prepare Workspace: adım 1, 1 resimden 1.
    • Place the Lisa on a safe/sturdy surface.
    FixBot'a Sor
    Yorum Ekle
  2. Apple Lisa Disassembly, Removing Front Panel: adım 2, 2 resimden 1. Apple Lisa Disassembly, Removing Front Panel: adım 2, 2 resimden 2.
    • Press the two tabs underneath to release the panel.
    FixBot'a Sor
    Yorum Ekle
  3. Apple Lisa Disassembly, Remove Drive Cage: adım 3, 1 resimden 1.
    • Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
    FixBot'a Sor
    Yorum Ekle
  4. Apple Lisa Disassembly, Remove Back Panel: adım 4, 2 resimden 1. Apple Lisa Disassembly, Remove Back Panel: adım 4, 2 resimden 2.
    • Twist thumbscrews on the back to release the panel. Pull panel up to remove.
    FixBot'a Sor
    Yorum Ekle
  5. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 1. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 2. Apple Lisa Disassembly, Remove Power Supply: adım 5, 3 resimden 3.
    • Release the thumbscrew on the power supply. Pull out the power supply.
    FixBot'a Sor
    Yorum Ekle
  6. Apple Lisa Disassembly, Remove Cardcage: adım 6, 2 resimden 1. Apple Lisa Disassembly, Remove Cardcage: adım 6, 2 resimden 2.
    • Grab the card cage at the location shown and pull out.
    FixBot'a Sor
    Yorum Ekle
  7. Apple Lisa Disassembly, Remove Top: adım 7, 2 resimden 1. Apple Lisa Disassembly, Remove Top: adım 7, 2 resimden 2.
    • Unscrew two philips screws on the ceiling of where the card cage was.
    FixBot'a Sor
    Yorum Ekle
  8. Apple Lisa Disassembly, Remove Power Switch: adım 8, 2 resimden 1. Apple Lisa Disassembly, Remove Power Switch: adım 8, 2 resimden 2.
    • Release two screws and release the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  9. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 1. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 2. Apple Lisa Disassembly, Remove Right Panel: adım 9, 3 resimden 3.
    • Remove all screws shown.
    FixBot'a Sor
    Yorum Ekle
  10. Apple Lisa Disassembly, Remove Left Panel: adım 10, 2 resimden 1. Apple Lisa Disassembly, Remove Left Panel: adım 10, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  11. Apple Lisa Disassembly, Remove Feet Panel: adım 11, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  12. Apple Lisa Disassembly, Remove Bottom Pannel: adım 12, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  13. Apple Lisa Disassembly, CRT: adım 13, 1 resimden 1.
    • I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
    FixBot'a Sor
    Yorum Ekle
  14. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 1. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 2. Apple Lisa Disassembly, Remove Cards: adım 14, 3 resimden 3.
    • Pull up on the tabs to remove cards.
    FixBot'a Sor
    Yorum Ekle
  15. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 1. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 2. Apple Lisa Disassembly, Remove Card Mount: adım 15, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
LisaGuide
1.833 İtibar
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 58
Her zaman: 3,113
