Ana içeriğe geç
Apple Mighty Mouse Scrollball Disassembly
Neye ihtiyacın var
    1. Apple Mighty Mouse Scrollball Disassembly, How to clean Apple Mighty Mouse scroll ball: adım 1, 1 resimden 1.
      • Before you continue, turn off the mouse using the slide switch underneath the mouse.
      • Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
      • You can also try blowing into the "ball hole" with a can of compressed air.
      FixBot'a Sor
      Yorum Ekle
    1. Apple Mighty Mouse Scrollball Disassembly, Apple Mighty Mouse Scrollball Disassembly: adım 2, 3 resimden 1. Apple Mighty Mouse Scrollball Disassembly, Apple Mighty Mouse Scrollball Disassembly: adım 2, 3 resimden 2. Apple Mighty Mouse Scrollball Disassembly, Apple Mighty Mouse Scrollball Disassembly: adım 2, 3 resimden 3.
      • Begin by flipping the mouse over, as shown.
      • Remove the bottom panel by pushing the release latch down and to the left.
      • You may need to pry the edge of the bottom panel up in the indicated area.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    2. Apple Mighty Mouse Scrollball Disassembly: adım 3, 2 resimden 1. Apple Mighty Mouse Scrollball Disassembly: adım 3, 2 resimden 2.
      • Insert spudger between button and outer white ring.
      • Twist the spudger to separate the ring from the body of the mouse. Work the spudger around the whole mouse until the ring is completely detached.
      • You must use some force to break the adhesive that holds the ring in place, but try not to crack the plastic ring.
      • You will have to glue this ring back to the mouse body when reassembling it. Cyanoacrylate adhesive works well.
      FixBot'a Sor
      Yorum Ekle
    3. Apple Mighty Mouse Scrollball Disassembly: adım 4, 1 resimden 1.
      • Undo two clips using a spudger.
      • Similarly, use the spudger to unhook two pivot points.
      FixBot'a Sor
      Yorum Ekle
    4. Apple Mighty Mouse Scrollball Disassembly: adım 5, 1 resimden 1.
      • Carefully separate the two halves; do not pull on the flex cables.
      FixBot'a Sor
      Yorum Ekle
    5. Apple Mighty Mouse Scrollball Disassembly: adım 6, 2 resimden 1. Apple Mighty Mouse Scrollball Disassembly: adım 6, 2 resimden 2.
      • Gently unlock the latches with a fingernail or a spudger. Do not stress the latch, or it might break.
      • Disconnect both flex cables.
      • The second photo shows how far to pull the latches.
      • When reassembling the mouse, both cables should be inserted into the connectors contact-side-up.
      FixBot'a Sor
      Yorum Ekle
    6. Apple Mighty Mouse Scrollball Disassembly: adım 7, 2 resimden 1. Apple Mighty Mouse Scrollball Disassembly: adım 7, 2 resimden 2.
      • Remove three Phillips #00 screws that attach the scrollball assembly to the upper shell.
      FixBot'a Sor
      Yorum Ekle
    7. Apple Mighty Mouse Scrollball Disassembly: adım 8, 1 resimden 1.
      • Pry the white ball cover out of the black housing with a small flat-head screwdriver.
      • There are small loose parts in the Assembly, be careful when removing the cover. The small magnetic wheels are especially easy to lose.
      FixBot'a Sor
      Yorum Ekle
    8. Apple Mighty Mouse Scrollball Disassembly: adım 9, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the four rollers from the black housing with tweezers. They are held in place magnetically.
      • Clean all parts in isopropyl alcohol, allow them to dry, and reassemble the device.
      • When reassembling the Assembly, the Rollers are placed back with the back wheel end touching the metal tabs.
      FixBot'a Sor
      Yorum Ekle
Sonuç
145 farklı kişi bu kılavuzu tamamladı.
Alex Jansen
9.257 İtibar
2 adet Kılavuz yazıldı
50Kılavuz Yorumları
Confirmed: these instructions work just fine for the usb version. The ribbon cable connectors are positioned slightly differently, but otherwise, exactly the same process. My usb mighty mouse is now like brand new. Thanks.
manwithfire - Yanıt Paylaş
Very good guide, worked very well for USB version as well, cable connector sitting in different positions but it's not a problem. Fixed my mouse in about 15 minutes, I would say it was easy.
Thanks!
Tobias - Yanıt Paylaş
thanks, it worked perfectly.
olivierfrein - Yanıt Paylaş
Great guide. I followed it and re-assembled my wireless mighty mouse, only problem though, now the ball only scrolls up. When I scroll up, down, left, or right, the page scrolls upwards in all cases. Any tips?
Omar ElHagin - Yanıt Paylaş
I guess I screwed it. Something went wrong with one of the flex cables, so that the scrollball works fine, but the pointer doesn't move any more. F**k.
lomez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 33
Son 30 gün: 184
Her zaman: 147,828
