Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn computer over.
Remove battery expansion cover and battery.
With monitor hinge at the bottom, remove the two top center screws.
Open computer kickstands.
Remove screws underneath each kickstand.
Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
Removing both ribbon cables from the motherboard will leave the clamps like so.
From here you can access the logic board, hard drive, and floppy drive.
Open the panel on back of the device. Remove 2 T8 torque screws.
Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
Once the old Memory board is removed, replace it with the new Memory board.
2 farklı kişi bu kılavuzu tamamladı.
