Ana içeriğe geç
Apple PowerBook G3 400 Hard Drive Replacement
Neye ihtiyacın var
  1. Apple PowerBook G3 400 Hard Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Your computer should look approximately like this.
  4. Apple PowerBook G3 400 Hard Drive Replacement, RAM: adım 4, 1 resimden 1.
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
  5. Apple PowerBook G3 400 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
  6. Apple PowerBook G3 400 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
  7. Apple PowerBook G3 400 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Lift up the heat sink unit from the left side and remove.
  8. Apple PowerBook G3 400 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
  9. Apple PowerBook G3 400 Hard Drive Replacement: adım 9, 1 resimden 1.
    • After removing the RAM, your laptop should now look like this.
  10. Apple PowerBook G3 400 Hard Drive Replacement, Hard Drive: adım 10, 1 resimden 1.
    • Locate the orange tab, which should be just left of the hard-drive.
    • You must disconnect this orange tab from the logic board to enable the next step.
    • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
  11. Apple PowerBook G3 400 Hard Drive Replacement: adım 11, 1 resimden 1.
    • Grab the plastic strip shown here and gently remove, pulling up and left.
    • Pull left to avoid the hard drive catching the casing.
  12. Apple PowerBook G3 400 Hard Drive Replacement: adım 12, 1 resimden 1.
    • Once you have removed the hard-drive, your laptop should like this.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kevin Keegan
75 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G2
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
This is unnecessarily complicated and a danger to several connectors of your precious laptop: The hard drive bracket can be removed as soon as the RAM heat shield has been removed. No need to strain the CPU board connector.
When the hard drive bracket is out of the case, the cable can be disconnected safely from the hard drive.
The keyboard doesn't have to be disconnected either, it can just be put on the hand rest.
Tobias Welti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 2,864
