Ana içeriğe geç
Apple PowerBook G3 400 Keyboard Replacement
    1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
      • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
      FixBot'a Sor
      Yorum Ekle
    2. Apple PowerBook G3 400 Keyboard Replacement: adım 2, 1 resimden 1.
      • Pull the keyboard ribbon vertically from the logic board to release connection.
      • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
      • Remove battery and CD/DVD drives before proceeding any further.
      FixBot'a Sor
      Yorum Ekle
    3. Apple PowerBook G3 400 Keyboard Replacement: adım 3, 1 resimden 1.
      • Your computer should look approximately like this.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Byron Hoefer
70 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-2, Regan Spring 2011 Cal Poly, Team 4-2, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G2
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 2,193
