Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This repair will need:
A T8 Torx Screwdriver.
Parçalar
Hiçbir parça belirtilmedi.
  1. With the Generally Disassembly completed, you may proceed to floppy drive installation.
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Remove the plastic panel at the bottom of the display.
    • Remove the plastic panel at the bottom of the display.
  3. Reverse the computer to access the peripheral panel in the back.
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Reverse the computer to have the monitor and mousepad facing you.
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Remove the three T8 Torx screws securing the floppy drive to the frame.
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Lift the defective floppy drive from the body of the computer.
    • Lift the defective floppy drive from the body of the computer.
  8. Replace the defective drive with a new drive.
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kevin Peters
120 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G66
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 2,293
