Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
With the Generally Disassembly completed, you may proceed to floppy drive installation.
Remove the plastic panel at the bottom of the display.
Reverse the computer to access the peripheral panel in the back.
Remove the two T8 Torx screws on either side of the bar code panel.
Reverse the computer to have the monitor and mousepad facing you.
Remove the plastic panel underneath the display.
Remove the three T8 Torx screws securing the floppy drive to the frame.
Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Lift the defective floppy drive from the body of the computer.
Replace the defective drive with a new drive.
Follow these instructions in reverse order to reassemble the device.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
