Ana içeriğe geç
Apple Powerbook 520 Hard Drive Replacement
Neye ihtiyacın var
  1. Apple Powerbook 520 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • After completing the initial disassembly, you may proceed to hard drive replacement.
  2. Apple Powerbook 520 Hard Drive Replacement: adım 2, 2 resimden 1. Apple Powerbook 520 Hard Drive Replacement: adım 2, 2 resimden 2.
    • First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame.
    • Next, you will remove the mounting frame and the plastic shield.
  3. Apple Powerbook 520 Hard Drive Replacement: adım 3, 1 resimden 1.
    • You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
  4. Apple Powerbook 520 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Carefully, pry the ribbon away from the pins.
  5. Apple Powerbook 520 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tyler
142 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-66, Walters Spring 2011 Cal Poly, Team 20-66, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G66
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 5,002
