Ana içeriğe geç
Apple Powerbook 520/540 General Disassembly
Neye ihtiyacın var
  1. Apple Powerbook 520/540 General Disassembly, Case: adım 1, 2 resimden 1. Apple Powerbook 520/540 General Disassembly, Case: adım 1, 2 resimden 2.
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: adım 2, 1 resimden 1.
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - Yanıt
    The Screws are T8!
    Willy Kaiser - Yanıt
  3. Apple Powerbook 520/540 General Disassembly: adım 3, 1 resimden 1.
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
  4. Apple Powerbook 520/540 General Disassembly: adım 4, 1 resimden 1.
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: adım 5, 1 resimden 1.
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
    Philips PH00 screws
    8-Bit Hero Wendler - Yanıt
  6. Apple Powerbook 520/540 General Disassembly: adım 6, 1 resimden 1.
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: adım 7, 3 resimden 1. Apple Powerbook 520/540 General Disassembly: adım 7, 3 resimden 2. Apple Powerbook 520/540 General Disassembly: adım 7, 3 resimden 3.
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mark McNeff
497 İtibar
2 adet Kılavuz yazıldı
2 Yorum
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Yanıt
Thanks been trying to fix this for a long time
Luke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 6,684
