Giriş
This set of instructions covers the Apple Powerbook 190/5300 Series’ hard drive removal and replacement.. This procedure should be performed for the replacement of a faulty or inoperable hard drive; including but not limited to data cable damage, or power cable damage. The user may also want to remove their hard drive to secure their data from compromise.
This device contains the highest voltage of any Powerbook of its time, and requires precaution. Remove the battery and power adaptor before the procedure.
Neye ihtiyacın var
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Turn the laptop back over and open the monitor.
With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
Use a spudger under one of the keys on the bottom row to very gently lift until you can use your hand to lift the keyboard.
Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
2 farklı kişi bu kılavuzu tamamladı.
