Ana içeriğe geç
Apple Powerbook 5300 Memory Replacement
Neye ihtiyacın var
  1. Apple Powerbook 5300 Memory Replacement, Battery: adım 1, 2 resimden 1. Apple Powerbook 5300 Memory Replacement, Battery: adım 1, 2 resimden 2.
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
    FixBot'a Sor
    Yorum Ekle
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: adım 2, 1 resimden 1.
    • For the next step you are to grab the TR8 Torx Security Screwdriver
    • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
    • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
    FixBot'a Sor
    Yorum Ekle
  3. Apple Powerbook 5300 Memory Replacement: adım 3, 1 resimden 1.
    • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
    FixBot'a Sor
    Yorum Ekle
  4. Apple Powerbook 5300 Memory Replacement, Memory: adım 4, 1 resimden 1.
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Scott
155 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G30
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 2,868
