Ana içeriğe geç
Apple Studio Display M2454 Main Computer Cable Replacement
Neye ihtiyacın var
    1. Apple Studio Display M2454 Main Computer Cable Replacement, Main Computer Cable: adım 1, 1 resimden 1.
      • First, the back panel needs to be removed to access the cable connectors.
      • Locate the three 2mm hex screws located on the top of the stand and remove them.
      • Now locate and remove the four 2mm hex screws on the corners of the back panel.
      • Now remove the back panels while pulling the cable through them without damaging either part.
      FixBot'a Sor
      Yorum Ekle
    2. Apple Studio Display M2454 Main Computer Cable Replacement: adım 2, 1 resimden 1.
      • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
      • Now remove the two other philips screws located below the cable with the philips head screwdriver.
      • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
      • Pull the metal plate away.
      FixBot'a Sor
      Yorum Ekle
    3. Apple Studio Display M2454 Main Computer Cable Replacement: adım 3, 1 resimden 1.
      • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
      • Pull bracket away from monitor.
      FixBot'a Sor
      Yorum Ekle
    4. Apple Studio Display M2454 Main Computer Cable Replacement: adım 4, 1 resimden 1.
      • Remove the cable hold-down with #2 phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Apple Studio Display M2454 Main Computer Cable Replacement: adım 5, 1 resimden 1.
      • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
      • Pull the plastic bracket free.
      • Note the plastic pegs lining the bracket up with the monitor.
      FixBot'a Sor
      Yorum Ekle
    6. Apple Studio Display M2454 Main Computer Cable Replacement: adım 6, 1 resimden 1.
      • Remove tape holding down the white connector to the LCD main board.
      FixBot'a Sor
      Yorum Ekle
    7. Apple Studio Display M2454 Main Computer Cable Replacement: adım 7, 1 resimden 1.
      • With tape removed, the connections on the LCD main board can be disconnected.
      • First, remove the single hold-down using the philips head screwdriver.
      • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
      • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
      • The tabs can easily break off, be extra careful
      • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
      FixBot'a Sor
      Yorum Ekle
    8. Apple Studio Display M2454 Main Computer Cable Replacement: adım 8, 1 resimden 1.
      • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
      • Remove the connector by hand.
      FixBot'a Sor
      Yorum Ekle
    9. Apple Studio Display M2454 Main Computer Cable Replacement: adım 9, 1 resimden 1.
      • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Dylan Perry
177 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G27
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 6,476
